Free syntax formula insertion
Free syntax formula insertion - Сообщения
#1 Опубликовано: 24.01.2017 03:01:56
Evgenij
Evgenij
1 сообщений из 8 понравились пользователям.
Hi all. I'm stuck about how can I insert reference formula into my home assignment.
Because they may have extended syntax or simply they should appear twice in the document.
First time as a reference formula, second as a calculation. And when they appear for the
first time I don't won't SMath to translate them.
The best way I found is to type formula in the on-line Latex converter and then insert them
as picture.
#2 Опубликовано: 24.01.2017 03:38:49
just use only logical equal to (CTRL+=) in your reference formula and nothing is going to be calculated.
