Addtional Result in Programming Line Function
Addtional Result in Programming Line Function - Is it possible to show more than one result when using the line (programming) function? - Сообщения
#21 Опубликовано: 28.07.2023 11:00:47
Laurent Fournier
Laurent Fournier
9 сообщений из 66 понравились пользователям.
Beautiful examples!
Thanks to everyone!
#22 Опубликовано: 28.07.2023 14:43:57
Jean,
I'm sorry, I don't understand what you are trying to explain.Would you be able to provide some additional details, please?
Thanks, Peter
These two attachments are sanity check Solver 30405.
As you download, they will reside in the same Download Directory.
Simply open ... Test UpDated.sm
This include session fits 7 data sets in no time,
respectively with iter parameter, init parameters,
and respectively with each individual model function.
You will have to resize each plot.
Please, let me know if successful.
Cheers ... Jean.
GenfitAlgoInclude.sm (36,06 КиБ) скачан 1391 раз(а).
Genfit Algo Include Test UpDated.sm (138,54 КиБ) скачан 1428 раз(а).
