1 страниц (5 вхождений)
[SS-3532] Custome Postfix Operator - Can I create my own definitions with a postfix operator - Сообщения
In MathCAD, the evaluation toolbar has custom in/post/pre/treefix operators. Of particular interest to me at this moment is the postfix operator ([Ctrl][Shift]X in MathCAD). I need to define Decibels (dB ) which is a scale and not a proper unit.
Thank you
Thank you
interesting, this is what you are referring to:
http://goo.gl/QvBBm
and this is an implementation of decibels in mathcad :
http://goo.gl/JWeKD
http://goo.gl/QvBBm
http://goo.gl/JWeKD
Yes. Interesting, Valery never showed me that was of doing decibles in MathCAD. Tom Gutmann showed me how to properly create a "new" unit name with the postfix operator, and there is another thread for electrical
SS-3532
I can think of a few scale units...
dB, pH, psia/psig
psia/psig is currently intriging for me because the scaling factor is calculated from a function. Considering SMath works in absolute scales, psi should be renamed psia or psi(a). In the one comversation i could find on this topic, https://en.smath.info/forum/yaf_postst468_Unit-Temperatures-possible-improvement.aspx, Randovan's example is that pressure conversion scale is @ 14.7 psi. This is not always the case. I'm looking at a problem concerning compressed air in Denver where the conversion scale is 12.3. My function works correctly but is based off of elevation and I cannot properly define the unit. I'll post my example when I get to a computer
Posting sheet that was used in the bug report
dB, pH, psia/psig
WroteBUG.smz (3,96 КиБ) скачан 1868 раз(а).
Will the CTRL+K allow us to define the scale of dB? Inspired from
WroteHowever, yes, can be done even this (CTRL+K to add the backslash)
