changing units in function results
changing units in function results - Сообщения
#1 Опубликовано: 02.06.2011 19:36:55
kilele
kilele
133 сообщений из 397 понравились пользователям.
I can't change units of this matrix ? Is this a bug ?
Thanks
[LIVE width=301 height=302]http://smath.info/live/?file=2826[/LIVE]
#2 Опубликовано: 03.06.2011 02:32:56
I think it was already mentioned this on the Forum.
SMath matrix elements can be of different type (text, numbers, units etc.). If you display matrix with elements which consist units - there will be default units diaplayd ('m instead 'mm here) and you can not change the units inside matrix. I think that this feature is not implemented yet. As a workaround, you can just display the particular matrix element and then change the units into the desired one.
