TWO Unreported Bugs
TWO Unreported Bugs - TWO Unreported Bugs - Сообщения
#1 Опубликовано: 17.09.2018 10:16:51
1. root element missing ... up until now, this kind of crash
happened on Smath crash [miscoding, infinite loop ...]
My "Polynomial Regress Quick" was fine and not used for months.
Last week, try to open root element missing then zapped.
No problem to rescue from the earliest saved backup [USB D]
If caused by Smath: a damned bug ! How could have it be caused from Win 7 ???
2. The 2nd bug is something else, it belongs to latest SS
Lately [2 days ago], I open the Rotavirus doctored by Alvaro ... fine.
Works fine SS 6179, but breaks linking to other C:\ folders and D:\ folders.
All other SS 6179 work sheets are accessible from C:\Samth6179 folder.
Hopefully, it's just a bug ... not from designed coding to force upgrade.
#2 Опубликовано: 17.09.2018 11:18:28
Hello Jean,
This is already reported here.
It shouldn't be a problem anymore since SS 0.98.6398 or 0.99.6626, at least it's what we think; unfortunately who posted the bug rarely has provided enough informations to know if the issue was triggered by a program version lower or greater than the ones in the range I've mentioned (to understand if it is still a thing). I've added a message at the end of the thread, though.
Holy backups
I do not understand what you mean by "breaks linking to other C:\ folders and D:\ folders";
Could you attach the file and elaborate a little? Thank you.
