Error Message Nominal - not defined
Error Message Nominal - not defined - Define error message and how to implement V-Lookup - Сообщения
#1 Опубликовано: 24.09.2013 22:15:55
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
I was trying to implement the V-Lookup routine posted here:
http://en.smath.info/forum/yaf_postst673_lookup.aspx
However I receive the error "Nominal - not defined".
My questions are as follows:
1. Is there a location where I can find more information on the error messages.
2. What am I doing wrong in the attached page to recieve this message?
3. Is there a way to correct this?
SMath file:
https://www.dropbox.com/s/hutlsgwmv3jvebd/STR%20-%20Out-Of-Plane.sm
Thanks and sorry if this is basic...I am a new user.
Ryan
STR - Out-Of-Plane.sm (11,08 КиБ) скачан 1399 раз(а).
#2 Опубликовано: 25.09.2013 04:14:46
the first row of BPT consists of tags and not by variables
labels are shaking and should be placed in quotation marks
for example "Nominal"
Davide Carpi 25.09.2013 06:27:00
#3 Опубликовано: 30.09.2013 14:24:34
Ryan Freund
Ryan Freund
Thank you
