question of roots
question of roots - Сообщения
#1 Опубликовано: 31.08.2023 15:43:11
Prmtv
Prmtv
0 сообщений из 49 понравились пользователям.
Hello. I can't understand. Why does it turn out 4 roots or not 2? Thanks.
#2 Опубликовано: 01.09.2023 01:10:52
1 124 сообщений из 1 796 понравились пользователям.
Hi. Because that's how what might be called "scalar expansion" for sys() works. Perhaps the result you are looking for is this using vectorize()
sergio 01.09.2023 04:49:00
#3 Опубликовано: 01.09.2023 13:43:31
Prmtv
Prmtv
Thanks!
How it is better to set then an array of the data? Need to get a solution for some data (for example: values a 4, 5, 6, 7...)
Matrix didn't work either.
#4 Опубликовано: 02.09.2023 15:07:12
Hi. Supposedly, vectorize operates only on matrices.
Need to get a solution for some data (for example: values a 4, 5, 6, 7...) Matrix didn't work either.
It should have worked. Do you have an example of how it didn't work?
#5 Опубликовано: 02.09.2023 18:51:05
Visit the Samples ... find zillions of examples.
#6 Опубликовано: 02.09.2023 20:35:19
You can use range() functions.
