Run exe file in DOS from Smath
Run exe file in DOS from Smath - Сообщения
#1 Опубликовано: 09.07.2018 13:39:58
Oscar Ugaz
Oscar Ugaz
3 сообщений из 2 понравились пользователям.
Guys,
1) Is it possible to run an .exe file from a DOS shell within Smath, and how ?
2) Could it be done by writing a Visual Basic script in the script window inside Smath ?
If so, could someone provide a small example of this.
Thank you for your help.
Oscar
#2 Опубликовано: 10.07.2018 07:59:25
The image region plugin demonstrates that you can run windows programs from within SMath.
If you register a dos program as standard application for png images, then the image region should launch this program whenever you try to create/edit the image.
Note that this might be considered as a security issue.
#3 Опубликовано: 18.07.2018 14:51:21
Try this.
Arie 18.07.2018 16:50:00, frapuano 18.07.2018 17:17:00
#4 Опубликовано: 19.07.2018 05:39:12
You can even use an hperlink region.
Absolutely. Assuming you are able to identify the threats, hyperlink regions are filtered by the user action (click of the user on the link), script region can be filtered by disabling auto calculation (before opening the worksheets).
