Problem with l/min unit
Problem with l/min unit - Сообщения
#1 Опубликовано: 11.11.2020 15:14:03
EngMath
EngMath
0 сообщений из 51 понравились пользователям.
I have a problem with units again. Can you help me ? Here's my input (I've also attached the .sm file):
D = 80 mm
d = 45 mm
f = 500 mm
t = 9 s
S = (π*(D^2-d^2))/4
Q = (S*f)/t
Result of the last formula is given in m^3/s but I would like to convert it to l/min (liters per minute). I click on the right placeholder and type: 'l/'min but the output I get is wrong:
What can I do to fix this ?
Liters per minute.sm (4,82 КиБ) скачан 1529 раз(а).
#2 Опубликовано: 11.11.2020 15:35:13
Liters "L" and not "l"
Davide Carpi 12.11.2020 10:10:00, EngMath 30.05.2021 09:05:00
#3 Опубликовано: 11.11.2020 16:31:19
EngMath
EngMath
It works now, thank you very much.
