[X-Y Plot] Smath Page Freezing
[X-Y Plot] Smath Page Freezing - Can't scroll to end of page - Сообщения
#1 Опубликовано: 02.02.2017 11:18:47
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
See attached SMath calc. There are a pair of graphs at the bottom but I can't scroll to see them. The SMath page freezes.
Any thoughts?
Masonry - STR - Out-Of-Plane - Wall - V1.sm (198,25 КиБ) скачан 1370 раз(а).
Thanks,
#2 Опубликовано: 02.02.2017 13:11:07
Arie
Arie
Fixed. In your definition of Pu_Mu right above you had M.u instead of M.U. Not sure why it cause a crash. But now it runs.
Masonry - STR - Out-Of-Plane - Wall - V1.sm (198,27 КиБ) скачан 1387 раз(а).
FYI, the way I fixed this was to disable auto calculation. Then I scrolled down and disabled evaluation of each graph. I enabled the graphs one at a time and manually recalculated each time. The left one caused the crash. When I only enabled the right graph, it produced the error showing M.u was undefined. Then I could find the bad definition from there.
Ryan Freund 02.02.2017 21:06:00, Davide Carpi 03.02.2017 04:33:00
#3 Опубликовано: 02.02.2017 23:45:11
Here, it does not crash but the work sheet is red from top to bottom.
