X^Y Power Function
X^Y Power Function - X^Y Power Function - Сообщения
#1 Опубликовано: 23.09.2019 09:26:31
I found no way to rescue the cumulative f(x) as given.
It must be reconstructed wrt scalar exp(x), ln(x) as indicated.
Result above max ... otherwise can't calculate.
Pure didactic for the unexpected red.
Integral 0Discrete Cumulative.sm (31,65 КиБ) скачан 1401 раз(а).
#2 Опубликовано: 23.09.2019 11:51:54
Here is the scalar reconstruction ... two same plots.
Bad luck: native Smath Simpson integrator is inadequate.
In any cases of integration, always wise to sanity
cumulative integration from FD [Finite Differences].
The simplest FD in this forum has been tested exhaustively
vs more advanced FD [F.B. Hildebrand] ... not to avail.
Considering noisy data sets, unless you can declare the
model fit function exact: FD will integrate the noisy
data set very closely true, directly from the noisy set.
Integral 0Discrete Cumulative [Simpson freak].sm (15,93 КиБ) скачан 1230 раз(а).
frapuano 25.09.2019 13:22:00
