String Join
String Join - Does it act as intended? - Сообщения
#1 Опубликовано: 15.01.2022 22:12:21
According to code it should throw a "string exception" for vector.
But, as you can see, it doesn't. Am I mistaken here?
Or did this function coded as it should be?
Code:
Click to enlarge
#2 Опубликовано: 16.01.2022 06:24:48
Try to use And (&&) operator instead of Or (||). These kinds of questions are best asked by the debugger.
overlord 17.01.2022 09:46:00
#3 Опубликовано: 16.01.2022 08:01:00
Yep, it should be AND instead of OR, I'll fix it later today. Thank you both
#4 Опубликовано: 16.01.2022 11:00:50
Plugin updated
overlord 17.01.2022 05:42:00
