copied text is clipped
copied text is clipped - only part of selected text line is copied - Сообщения
#1 Опубликовано: 25.04.2018 05:52:44
m227
m227
4 сообщений из 29 понравились и 1 не понравились пользователям.
my problem is that if I select whole text line and try to copy it and paste to notepad (or back to the same SMath sheet) I get only part of selected text.
Steps to reproduce:
1. open new worksheet
2. input this text:
Цитата
a el(Re.a,1,1):{nthroot(Re/b,3)+sqrt(3.6)}/sin(3)/{4^{2-o}}}
- as there is a space as second char, this is treated as text region (alternatively one can use Insert->Text region and then insert this text or similar).
Then double click on inserted text. All text is selected. Then copy (^C) and paste it (^V). Only part of text is copied. Attached sample file.
selection_copy_bug.sm (2,02 КиБ) скачан 1317 раз(а).
#2 Опубликовано: 25.04.2018 08:34:43
Just paste and manage the disposition.
