Generating Control Valve Curve using SMATH
Generating Control Valve Curve using SMATH - Сообщения
#1 Опубликовано: 22.04.2023 12:04:37
usamakhan
usamakhan
7 сообщений из 98 понравились пользователям.
I have Chinese valves where from nameplate I can get Cv @100% open & that its Equal%.
Now I generated a spreadsheet model which is fairly simple & then used 'Goal Seek' feature to iterate values such that I get stated Cv at 100% opening.
I am uploading procedure that I followed (this document also has a small video file)
I am also attaching spreadsheet file as well.
External server zip file: https://www.mediafire.com/file/8qhwt7riweby457/Characteristic+Curve+Generation.zip/file
Now how can I do this in SMATH Studio? I mean construct in such a way that I change one value such until I get required CV at 100% as well as each interval increment is equal percentage
Characteristic Curve Generation.zip (2,39 МиБ) скачан 483 раз(а).
#2 Опубликовано: 22.04.2023 21:06:30
ValveCv.pdf (76,19 КиБ) скачан 924 раз(а).
ValveCv.sm (13,89 КиБ) скачан 1382 раз(а).
#3 Опубликовано: 24.04.2023 09:21:14
If your valve would be Fisher Controls, you should be able
to reach the catalog page c/w cv/% opening + more valve data.
This document fits = % & quick opening.
As a separate Smath document, I have the Fisher valve sizing procedure,
including the pulp stock.
Cheers ... Jean.
Fisher.sm (34,21 КиБ) скачан 1434 раз(а).
#4 Опубликовано: 24.04.2023 14:06:51
usamakhan
usamakhan
Extremely thanks Razonar & Jean
