1 страниц (4 вхождений)
Deleting picture in smath file not possible - Сообщения
Hey,
while working i considere a problem with a jpg picture.
I can put it in the smath file but i am not able to re delete the picture.
Deleting Picture not possible.sm (544,4 КиБ) скачан 1265 раз(а).
Is there somehow a way to delete the picture. The icon is grey so i cannot click it
Best regards Stefan
Best regards Stefan
You have to select the region then you can delete it (left-click on a point outside the region, hold down the mouse button and move over the region; it will become blue-colored).
![2021-09-02 12_12_53-SMath Studio - [Deleting Picture not possible.sm].png](/ru-RU/files/Download/UMRpor/2021-09-02-12_12_53-SMath-Studio---[Deleting-Picture-not-possible.sm].png)
This is a general rule. Any region when focused (left click on the region) it is supposed on interaction within the content and therefore you cannot delete the container (also depending on the region you might have different options in the context menu when it is focused or selected).
Stefan Müller 07.09.2021 07:21:00
ok thank you i got it :-)
Stefan,
1. Capture/select your image [Paint, WinGrab ...]
2. Paste in IrfanView ... check if you can reduced colors
3. In IrfanView, you can sharpen from poor web image.
4. ... as well resample/resize
At this point, copy/paste in your Smath work sheet.
Click on the image, press Delete from the keyboard.
