png order in htm
png order in htm - Сообщения
#1 Опубликовано: 08.12.2009 14:12:02
Waluyo Adi Siswanto
Waluyo Adi Siswanto
1 сообщений из 55 понравились пользователям.
When I save sm as htm and see the source, the order of png images is very strange,starting the last number on top and the lowest number (...._0.png) at the bottom.
It creates a problem when I convert into Latex using html2latex, the order will be following the list written in htm file, not considering the position absolute.
Is that possible I can get the order
Thanks and regards
waluyo
#2 Опубликовано: 09.12.2009 14:02:25
2 342 сообщений из 4 041 понравились пользователям.
Группа: Super Administrator
Will check later today... and fix Thanks.
