Unit Display
Unit Display - volts display as volts - Сообщения
#1 Опубликовано: 12.03.2014 14:53:47
hip
hip
I need a voltage output to read V not {'kg*'m^2*'H}/{'A*'s^4}. I know I am missing something simple but I have hours into searching examples and forums, and even read where A*Ohms was supposed to be a default simplification. I even redid a whole equation, then slid the V over next to my answer on my last report.
#2 Опубликовано: 12.03.2014 19:14:42
Mike Kaganski
Mike Kaganski
1. It is usually a good idea to attach an example file here, so that those who decide to devote their time helping are able to see what's going on. Without it, it's mostly impossible to say something helpful.
2. In your case, {'kg*'m^2*'H}/{'A*'s^4} equals to Ohm*V, not V, so you must have made some mistake in your calculations (or in units of your input). You may simply manually put V as units for your specific result, and see that Ohm will be added automatically to supplement the unit.
As I said above, there's nothing more to say given the information you supplied.
С уважением, Михаил Каганский
