1 страниц (6 вхождений)
Simple example solved in SMath - Сообщения
Hi All,
I have solved one of the text book problems using SMATH. Hopefully, someone will benefit.
VijayBasic_sine.sm (23,62 КиБ) скачан 1405 раз(а).
Davide Carpi 12.05.2018 04:03:00
Thank you Sir... I am an undergraduate in e.e. and appreciate your contribution. I often spend hours trying to work the syntax of SMath/Maxima plugin so having references is nice. I'm not sure if SMath leaves me scratching me head less than Matlab but I'm a beginner so I'll have to stay at it.
P.S. I tried to thank you for the post but an error was generated upon clicking the "thank" button...
WroteThank you Sir... I am an undergraduate in e.e. and appreciate your contribution. I often spend hours trying to work the syntax of SMath/Maxima plugin so having references is nice. I'm not sure if SMath leaves me scratching me head less than Matlab but I'm a beginner so I'll have to stay at it.
I am Happy it`s of use to you. I will post more examples in future. Also, I get a lot of help from the forum and I would like to acknowledge their contribution too. I have recently completed an example on Bode plots, I will post that shortly.
Vijay
WroteI have recently completed an example on Bode plots,
Did you visit the recent Sample Admittance Bode ?
WroteDid you visit the recent Sample Admittance Bode ?
Project Admittance Copy.sm (155,01 КиБ) скачан 1353 раз(а).
Good example. Thank you for sharing.
