Animated graphs -v0.90 versus v0.91
Animated graphs -v0.90 versus v0.91 - Сообщения
#1 Опубликовано: 02.02.2012 18:33:18
I think that everybody knows the famous Ber7 animations here on the Forum
I tried the few recent ones
https://smath.com/wiki/GetFile.aspx?File=Cannabis.rar
https://smath.com/wiki/GetFile.aspx?File=Graf1.rar
https://smath.com/wiki/GetFile.aspx?File=Graf2.rar
Unfortunately, they do not work the same as in v.0.90. Actually, the first one is not visible at all, and on the second two only the points are visible but not the curves. Is there any problem about it?
#2 Опубликовано: 02.02.2012 18:49:38
Группа: Super Administrator
Hello.
I mentioned about it earlier in that comment: http://en.smath.info/forum/default.aspx?g=posts&m=5921#post5921
Unfortunately all animations done with 0.90 must be updated like shown in the image below (all global variables changed within function must be specified as function arguments to fix graphs):
Unfortunately the error introduced in 0.90 was too bad
Best regards, Andrey Ivashov.
#3 Опубликовано: 02.02.2012 19:11:03
No harm done Andrey
Do not worry about it. It is another example about how is this suppose to work and just to clarify the things once more.
#4 Опубликовано: 02.02.2012 19:39:30
Fridel Selitsky
Fridel Selitsky
All animation files updated to version 0.91
Radovan Omorjan 02.02.2012 19:47:00, Andrey Ivashov 02.02.2012 19:48:00, frapuano 18.02.2018 08:49:00
#5 Опубликовано: 02.02.2012 19:47:22
Thank you very much!
Regards.
