1 страниц (4 вхождений)
SMath Studio and MathCAD - Сообщения
After starting to use SMath Studio, I think the software is brilliant and having not use MathCAD before I am wondering how much more MathCAD can actually do? Are there any users of the latest version of MathCAD and the latest version of SMath Stuio out there that can give us a brief summary of each (perhaps the strengths and weakness of each)? I do not want to start a Vs battle between the two, but simply understand each better.
I am very interested in this. Thanks.
There is no any definite answer to this question. Just have in mind that Mathcad is around here for almost 30 years, I think. Any user of Mathcad will give a different answer. Actually, it depends on what you need. If SMath is doing what you would expect it to do, that is Ok and you do not need Mathcad. There are also many posts under Feature Requests forum.
Thanks Radovan,
I am at quite a key stage in research at the moment, I can see myself using SMath Studio very much now and in the future (even if I get access to MathCAD). I am thinking of downloading the trial of MathCAD, can I open SMath Studio files in MathCAD? Is it compatible?
Thanks
Thanks
Although you can read/save SMath files in Mathcad *.xcmd format, the compatibility with Mathcad is quite poor. It will work only for rather simple files. Mathcad and Smath are quite different and I really do not know if there could be even better Mathcad support in SMath. The final answer could give you only the SMath creator, Andrey Ivashov.
