ScrollBarEx Region
ScrollBarEx Region - One more scrollbar control. - Сообщения
#1 Опубликовано: 02.05.2014 10:35:17
1 544 сообщений из 1 859 понравились пользователям.
Scrollbar control based on Regions.Control class.
Показать спойлер
Password: test
Used as an example of the region without a place holder.
Links:
1. Custom Drawn Scrollbar (Thomas Duwe).
Andrey Ivashov 02.05.2014 11:24:00, Davide Carpi 02.05.2014 11:38:00
#2 Опубликовано: 02.05.2014 11:41:04
1 441 сообщений из 2 932 понравились пользователям.
Cool
the right-click shows me an unhandled exception
************** text of exception **************
System.NullReferenceException: object reference not set to an instance of an object.
   in SMath.Control.Worksheet.GetStaticContextMenuItems(RegionBase[] regions)
   in ..(List`1 )
   in ..‡(Object , EventArgs )
   in System.Windows.Forms.ContextMenu.OnPopup(EventArgs e)
   in System.Windows.Forms.ContextMenu.Show(Control control, Point pos, Int32 flags)
   in System.Windows.Forms.Control.WmContextMenu(Message& m, Control sourceControl)
   in System.Windows.Forms.Control.WndProc(Message& m)
   in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
#3 Опубликовано: 02.05.2014 12:41:47
I decided to use my own Control class for quick porting of such components. Yes, some artifacts remain. This component will be used in a script (text) editor.
Regions.Control is a draft version, it's not so easy to create full functional Control class.
Davide Carpi 02.05.2014 14:47:00
