1 страниц (8 вхождений)
Output in tabular format - Сообщения
Suppose x=0,2/(n-1),...2 and n=15. How can I get output in tabular format for M(x), V(x) where M(x) and V(x)are function of x?
Shiwani.
Shiwani.
Thanks.
I have one more doubt related to table. If suppose all the output values are same for particular function then whether it will show me table having all same values or instead of table it will show me single value. e.g. suppose in previous example all the output values of M are 0 then whether it will show me M=0 or will show me table?
Shiwani.
Shiwani.
Do not quite understand, sorry. Why do not try it yourself and see?
WroteThanks.
Shiwani.
In case that all output values of M are 0, Smath will show the results in vector form
Thanks.
Going to Plot2D and inserting: augment(x,M)
I would expect to get the plot of the function but I do not.
Any idea?
Thank you,
Basile
Any idea?
Thank you,
Basile
Hello Basile,
You must not use augment(x,M) in the plot region control. Variables x and y are reserved for function plots in 2D and 3D plots. If you have to use vector named x, like in this case, than you should make a matrix first,say, A:=augment(x,M),and then put the matrix A in the plot region control.
