incorect result from previous calculation after redefined variable
incorect result from previous calculation after redefined variable - Сообщения
#1 Опубликовано: 07.05.2013 02:37:11
xyonx
xyonx
0 сообщений из 10 понравились пользователям.
this is a simple calculation where i do routine in small programming with python, sheet contains multiple branch & redefine variable, at the end of stage need to take result from a previous calculation.
i have a simple calculation, but get wrong results in SMATH.. can not figure out where i goes wrong, i try to make comparasion with MATHCAD
can anybody help, explain why i get wrong results?? thanx u
#2 Опубликовано: 07.05.2013 03:03:34
Mike Kaganski
Mike Kaganski
When you define [MATH]M,nxa[/MATH] you define it as a formula, that is recalculated every time its result is shown. So, the second time you see the second calculation using new lambdas. Try using eval() function: [MATH]M,nxa:eval(algorithm)[/MATH]
С уважением, Михаил Каганский
#3 Опубликовано: 07.05.2013 03:20:37
xyonx
xyonx
thanx for quick response,
yes, after using "EVAL" function the answer are correct as expected.
i don't know SMATH always recalculate with new variable even without redefined formula. this behaviour are differ from many others math programming.
regards,
