Edit a chart
Edit a chart - How to insert numbered points in a graph - Сообщения
#1 Опубликовано: 21.01.2020 15:49:24
Ale16595
Ale16595
0 сообщений из 35 понравились пользователям.
Hello to all.
I have traced these three functions, that depend on time, on the graph.
How can I insert numbered points, superimposed on the traced functions, so that the same numbering corresponds to the same instant of time?
To be clear, I should do something like the following figure …
This is the .sm file: CALCOLI TESI manovra.sm (69,86 КиБ) скачан 1157 раз(а).
thanks in advance for the help
#2 Опубликовано: 21.01.2020 16:53:21
using some good tips posted by Jean, you could do this:
CALCOLITESImanovra_s.sm (78,32 КиБ) скачан 1153 раз(а).
I preferred to refer to actual times and not to anonymous labels; however you can use the same methodology more easily
Ale16595 22.01.2020 08:32:00
#3 Опубликовано: 21.01.2020 18:39:09
Can you trace these functions from the previously doctored document.
Why jump ship [new thread] from suite to suite ?
#4 Опубликовано: 22.01.2020 14:36:11
Easy ... take the DE that I doctored before
there may be some sanity wrt the other two graphs.
Ale16595 22.01.2020 15:03:00
#5 Опубликовано: 23.01.2020 09:04:58
What's next past the DE ?
CALCOLI TESI manovra ... What Next.sm (70,75 КиБ) скачан 1206 раз(а).
