Triangular Mesh for 3D plots
Triangular Mesh for 3D plots - Сообщения
#1 Опубликовано: 23.10.2021 02:42:13
Hi. There are several variants for the triangular meshs. This is one.
pTriMesh.pdf (459,2 КиБ) скачан 909 раз(а).
pTriMesh.sm (29,35 КиБ) скачан 1571 раз(а).
Fridel Selitsky 23.10.2021 03:10:00, Oscar Campo 12.10.2022 08:46:00
#2 Опубликовано: 25.10.2021 03:40:35
Hi. Here are some notes about how the mesh is constructed. To include the missing vertices, they would have to be inserted at least twice, when drawing the diagonals. It could be done by constructing the mesh as it is, and instead of drawing the entire diagonal, to the center of the squares, but it could be a slow procedure. For another example, please see https://en.smath.com/forum/yaf_postsm74527_Offset-surface-creation.aspx#post74527
pTriMesh work.sm (28,8 КиБ) скачан 1520 раз(а).
Oscar Campo 12.10.2022 08:46:00, Fridel Selitsky 25.10.2021 03:58:00
#3 Опубликовано: 25.10.2021 21:28:47
This other have the intesections as part of the mesh.
pTriMesh_v2.sm (48,39 КиБ) скачан 1561 раз(а).
Oscar Campo 12.10.2022 08:46:00, overlord 25.10.2021 21:31:00
#4 Опубликовано: 18.11.2021 02:12:26
Hi. More general mesh utility, with a variable patern. Also, waterfall plots (matlab page here).
pWMesh.sm (193,8 КиБ) скачан 1555 раз(а).
pWMesh.pdf (3,2 МиБ) скачан 987 раз(а).
Oscar Campo 12.10.2022 08:46:00, Fridel Selitsky 18.11.2021 08:26:00
