Copy and paste a picture
Copy and paste a picture - Сообщения
#1 Опубликовано: 29.11.2011 17:43:55
abustillos
abustillos
1 сообщений из 4 понравились пользователям.
Hello! I would like to know how can I paste a picture from a word document or another Smathstudio file to a new Smath Studio sheet???
Thanks...
#2 Опубликовано: 29.11.2011 20:00:48
Edward Ulle
Edward Ulle
21 сообщений из 182 понравились пользователям.
Try Windows Cut and Paste.
I embed sketches in my SMath files all the time. That works for me.
Ed
#3 Опубликовано: 05.12.2011 14:22:14
abustillos
abustillos
The copy and paste function doesn't work in my file.......do you have any idea what could be wrong?
Thanks..
Fridel Selitsky 05.12.2011 15:54:00
#4 Опубликовано: 05.12.2011 15:33:59
kilele
kilele
What's wrong? It works for me at least in 0.89 stable.
Try right click over a picture in msword and copy it to clipboard, right click again over your smath sheet and paste.
#5 Опубликовано: 05.12.2011 17:24:43
Edward Ulle
Edward Ulle
I discovered you can not copy a picture directly to SMath. By directly I mean you can't copy a jpeg or tiff file. You need to open it with something like Paint and then copy and paste to SMath. I was able to copy a photo from Paint and Word to SMath, no problem.
Ed
#6 Опубликовано: 13.12.2011 05:51:46
benbig
benbig
I can insert picture "from file". But the picture can not then be stretched/resized after insert.
#7 Опубликовано: 13.12.2011 15:28:19
Unfortunately, It is not possible to stretch/resize the picture inside SMath at the moment.
#8 Опубликовано: 05.01.2012 18:00:18
amit28it
amit28it
0 сообщений из 16 понравились пользователям.
Copy and paste to a picture is as usual as windows .But i am also recently knowing that Smath can' adjust images a/c to users view as told by omorr.So i will think that he will be knowing the way to handle this .
#9 Опубликовано: 05.01.2012 18:08:21
...So i will think that he will be knowing the way to handle this .
You can not resize the picture inside SMath. Just try it and you will see that the picture region will be resized but the picture itself will not be adjusted. If you want to insert a picture into the SMath page, just resize it in some other picture managing software to the size you need.
I hope I understood your question and gave you the appropriate answer.
#10 Опубликовано: 03.02.2012 18:02:47
Shiwani Thakur
Shiwani Thakur
0 сообщений из 7 понравились пользователям.
How can I insert the snapshot of SMath file in post? I did try copy and paste, but its not working. The option 'Insert image' asks for URL link.
Thanks & regards,
Shiwani.
#11 Опубликовано: 03.02.2012 18:19:59
hi,
there are 2 ways:
- using the Wiki, as explained here Notes on Using the Forum
- by uploading your image in a external free image hosting service (like tinypic.com or imm.io) or in a external general file hosting service (like mediafire.com)
then you can copy the uploaded image link in the "Insert Image" on the forum...
w3b5urf3r
