bug with angles
bug with angles - Сообщения
#1 Опубликовано: 19.05.2012 10:42:35
plese look this strange behavior...
angle bug
angle bug
here is the file in the image: angle_debug.zip
regards,
w3b5urf3r
#2 Опубликовано: 19.05.2012 11:36:17
It is again all about optimization. Use Numerical optimization for the B_vfk, alpha_vfs or plot_2.
#3 Опубликовано: 19.05.2012 13:16:31
Группа: Super Administrator
Thank you! Will fix it too.
I plan to fix all the known bugs of 0.94 and release new version tomorrow in the evening.
#4 Опубликовано: 19.05.2012 14:04:45
Thank you very much
Another problem (I hope not to get you mad)...
Typing these characters an error message (System.NullReferenceException) will appear; then if you want to continue using the program will appear another message error (System.InvalidCastException)
these characters disappear if typed two times, and cause a similar error as above if typed 3 times (System.ArgumentOutOfRangeException)
P.S. the bracket ] introduce the line() command and then appear the error message
regards,
w3b5urf3r
#5 Опубликовано: 19.05.2012 14:32:17
You are right,
Just pressing ^ will cause the Unhandled exception (Win XP)
Here are the Details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SMath.Control.MathRegion.(Int32 , Term )
at SMath.Control.MathRegion.(String )
at SMath.Control.MathRegion.OnCommandSend(String value)
at SMath.Control.Worksheet.(String )
at SMath.Control.Worksheet.Insert(String value)
at SMath.Control.Worksheet.OnKeyPress(KeyPressEventArgs e)
at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
at System.Windows.Forms.Control.ProcessKeyMessage(Message& m)
at System.Windows.Forms.Control.WmKeyChar(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop
Assembly Version: 0.94.4521.40097
Win32 Version: 1.1.21.0
CodeBase: file:///D:/Downloads/Software/SMath/SMathStudio_Desktop.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman
Assembly Version: 0.94.4521.40086
Win32 Version: 0.94.4521.40086
CodeBase: file:///D:/Downloads/Software/SMath/ioman.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
canvas
Assembly Version: 0.94.4521.40092
Win32 Version: 0.94.4521.40092
CodeBase: file:///D:/Downloads/Software/SMath/canvas.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
HTMLFileType
Assembly Version: 1.9.4521.39825
Win32 Version: 1.9.4521.39825
CodeBase: file:///D:/Downloads/Software/SMath/plugins/HTMLFileType.dll
ImageFileType
Assembly Version: 1.5.4521.39839
Win32 Version: 1.5.4521.39839
CodeBase: file:///D:/Downloads/Software/SMath/plugins/ImageFileType.dll
PictureRegion
Assembly Version: 1.7.4521.39854
Win32 Version: 1.7.4521.39854
CodeBase: file:///D:/Downloads/Software/SMath/plugins/PictureRegion.dll
PlotRegion
Assembly Version: 1.6.4521.39867
Win32 Version: 1.6.4521.39867
CodeBase: file:///D:/Downloads/Software/SMath/plugins/PlotRegion.dll
SMathFileType
Assembly Version: 1.6.4521.39882
Win32 Version: 1.6.4521.39882
CodeBase: file:///D:/Downloads/Software/SMath/plugins/SMathFileType.dll
SpecialFunctions
Assembly Version: 1.8.4521.39899
Win32 Version: 1.8.4521.39899
CodeBase: file:///D:/Downloads/Software/SMath/plugins/SpecialFunctions.dll
TextRegion
Assembly Version: 1.7.4521.39913
Win32 Version: 1.7.4521.39913
CodeBase: file:///D:/Downloads/Software/SMath/plugins/TextRegion.dll
XMCDFileType
Assembly Version: 1.8.4521.39928
Win32 Version: 1.8.4521.39928
CodeBase: file:///D:/Downloads/Software/SMath/plugins/XMCDFileType.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
NuLib
Assembly Version: 1.61.4521.40090
Win32 Version: 1.61.4521.40090
CodeBase: file:///D:/Downloads/Software/SMath/NuLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
#6 Опубликовано: 20.05.2012 03:58:19
To be fixed today as well.
Regards.
Radovan Omorjan 20.05.2012 05:00:00, Davide Carpi 20.05.2012 05:44:00
#7 Опубликовано: 20.05.2012 14:26:33
Both errors fixed in SMath Studio 0.94.4523.
Best regards, Andrey Ivashov.
Davide Carpi 21.05.2012 04:55:00
#8 Опубликовано: 21.05.2012 05:13:50
great job, many bug fixed
unfortunately, the bug System.ArgumentOutOfRangeException persists...
involved characters:
these characters "disappear" if typed two times (text area of text and the hints window becomes white, and drawing a selection with the mouse, the selected portion of the sheet becomes white too), and cause the message error if typed 3 times; if you want to continue then you can't close the sheet from the X button or the exit option (the only way is CTRL+ALT+DEL)
regards,
w3b5urf3r
#9 Опубликовано: 21.05.2012 05:40:51
Hello w3b5urf3r,
I can't reproduce this and I thought this bug was "squashed" by Andrey.
Could you please explain what keys should we press in order to get this problematic behavior you've explained.
#10 Опубликовано: 21.05.2012 06:43:50
Just write in a blank area
§ -> no problem
§§ -> white areas
§§§ -> error message
here I shared a video to show what happens: Smath bug video (codec:XviD) (red points on pointer when clicking with left mouse button)
#11 Опубликовано: 21.05.2012 09:15:53
Thank you w3b5urf3r,
I reproduce it now. I used my keyboard and there was no £ key. Inserting £ as ALT-0163 will cause the problems that you've presented in the video file - forced closing of SMath was needed then. This is happening only in math regions.
#12 Опубликовано: 21.05.2012 09:52:14
Thank you for reproducing this bug...
It is not critical, but sometimes an "heavy finger" on the keyboard can come to light it
regards,
w3b5urf3r
#13 Опубликовано: 27.05.2012 12:54:36
Finally fixed:
Thank you!
Radovan Omorjan 27.05.2012 16:29:00, Davide Carpi 28.05.2012 07:33:00
