1 страниц (5 вхождений)
Rendering matrix columns - Last column of 6x6 matrix does not show. - Сообщения
I am showing the content of a numerical 6x6 matrix but the last column is not displayed, I can index into the last column so it is clearly just the rendering. Does anyone know of a way to get the 6th column to show?
WroteI am showing the content of a numerical 6x6 matrix but the last column is not displayed, I can index into the last column so it is clearly just the rendering. Does anyone know of a way to get the 6th column to show?
Something wrong ... definitly/definitively
Please, attach the document, it may need be doctored.
Utilities Matrix Delta.sm (40,61 КиБ) скачан 1193 раз(а).
The content might be hidden if the matrix is too large (number of elements or width/height)
Check if there are ellipsis displayed on the left/bottom edges and drag them aroud to display the hidden content.
Otherwise as suggested above attach the file that doesn't work for you
frapuano 24.02.2018 17:46:00
Thanks for replies - it does show an ellipsis and dragging has uncovered the hidden column. Problem solved!
WroteThanks for replies - it does show an ellipsis and dragging has uncovered the hidden column. Problem solved!
Problem solved <= Answer Problem NOT solved
The "ellipsis" feature [Smath 6179 ...] is convenient to display limited check from long
vector(s)/matrix ... however: can't be used to collect the entire result [it collect
what is displayed only]. To collect the entire result ... like this:
1. result
2. [result] from matrix drop down menu 1 row by 1 col
3. [result]= set decimal places, F9 to calculate
4. @ this point, you can export the entire vector/matrix.
