How make a histogram?
How make a histogram? - how can I make a histogram instead of a curve? - Сообщения
#1 Опубликовано: 12.07.2017 09:24:25
Adam
Adam
1 сообщений из 5 понравились пользователям.
curve.sm (3,68 КиБ) скачан 1239 раз(а).
#2 Опубликовано: 12.07.2017 10:33:13
A bar plot is just a bar plot. An "Histogram" is generally
plotted "bar", but may be "stem". An 'histogram' comes from
a large data set of collected values.
Does the attached help ?
Stat Histogram PW.sm (51,43 КиБ) скачан 1302 раз(а).
Stat Histogram Create Normal Random.sm (69,61 КиБ) скачан 1253 раз(а).
#3 Опубликовано: 12.07.2017 13:51:10
CBG
CBG
Using the Jean Code.
curve_R0.sm (7,22 КиБ) скачан 1260 раз(а).
Adam 14.07.2017 07:40:00
#4 Опубликовано: 12.07.2017 21:15:11
You could probably attempt fitting a model function.
Histograms are difficult to model/fit.
Genfit Frechet DIFFICULT.sm (34,28 КиБ) скачан 1310 раз(а).
Adam 14.07.2017 07:41:00
