Deleting (and adding) lines
Deleting (and adding) lines - Сообщения
#1 Опубликовано: 21.01.2011 06:54:33
zureks
zureks
0 сообщений из 9 понравились пользователям.
Hi. I know you heard it hundreds of times, but I will say it again - you guys created excellent software. I just donated $10 (not much I know) to help you just this little bit.
I know I can add new space/lines in the sheet by just pressing Enter - then all the stuff below is just pushed lower. But how to remove empty space and "pull up" what is below? Pressing backspace or delete does not work?
Stan
#2 Опубликовано: 21.01.2011 07:19:19
Hello Stan,
...Pressing backspace or delete does not work?
This is strange - BACKSPACE and DELETE should work.
If you put a pointer (red plus sign) between two regions (left mouse button click)
- ENTER will insert horizontal space moving the regions (below the red plus sign) DOWN (including the red plus sign)
- BACKSPACE will delete the space between regions moving the regions (below the red plus sign) UP (including the red plus sign)
- DELETE will delete the space between regions moving the regions (below the red plus sign) UP (the red plus sign will not move)
Is there any chance that you are using the Linux version?
#3 Опубликовано: 21.01.2011 07:41:12
zureks
zureks
It's Windows XP. I re-installed the SMath and the Backspace indeed works (pulls up), but delete does nothing (unless in a text or math region).
That's good enough for me anyway :-) Thanks.
