Euler Angles, Quaternions & Co.
Euler Angles, Quaternions & Co. - mb10 - Сообщения
#1 Опубликовано: 31.08.2013 03:30:05
mb10
mb10
9 сообщений из 20 понравились пользователям.
Attached is a file with formulas for 3D rotations transformations.
It can be used as a "snippet" (copy it in the "snippets" folder).
Currently supported conversions:
Euler angles to quaternions
Quaternions to rotation matrix
Euler angles to rotation matrix
Angle & vector to rotation matrix
Angle & vector to quaternions
Quaternions to Euler angles
Quaternions to angle & vector
Rotation Matrix to quaternions
For those unfamiliar on the matter, a comprehensive article is found here:
Review of Attitude Representations
Rotation Examples.sm (98,86 КиБ) скачан 1762 раз(а).
ioan92 02.09.2013 08:11:00, Davide Carpi 02.09.2013 14:09:00
#2 Опубликовано: 02.09.2013 10:56:36
mb10
mb10
Thank you very much for your comments.
For practical wider interest, please include, if possible, also the "Euler–Rodrigues Quaternion Formulation".
The AngVec2Quat and Quat2AngVec functions are intended to perform Euler-Rodriguez to Quaternion conversion and vice-versa, respectively: i.e. the Angle-Vector parameters correspond to the Euler-Rodriguez representation of rotations.
Best regards,
massimo
ioan92 02.09.2013 11:02:00
