Estimating Fricton Factor accurately
Estimating Fricton Factor accurately - A very accurate equation for calculating the friction factor directly, without trial and error - Сообщения
#1 Опубликовано: 17.05.2023 19:01:41
Javier Ochoa
Javier Ochoa
3 сообщений из 26 понравились пользователям.
Reading the article I could be able to calculate the friction factor for the Colebrook Equation and Reynolds number greater than 2500 for any ratio between the roughness and the diameter, due to the SMath Studio solvers with a set of 70 points simultaneously.
Then, I compared to other solutions found in two different articles and a table of the maximum absolute deviation and average deviation are presented at the end of the worksheet.
Hope it help,
Kind regards
friction_factor_Colebrook.sm (82,56 КиБ) скачан 1628 раз(а).
#2 Опубликовано: 17.05.2023 20:54:32
Hope it help,
Sorry ... not a bit ! We are CAS age [Computer Algebra System]
... of which Smath ranks top for Engineering applications.
Inst_Colebrook MOODY.sm (16,88 КиБ) скачан 1627 раз(а).
Inst_Colebrook Pipe Data.sm (75,07 КиБ) скачан 1758 раз(а).
Javier Ochoa 18.05.2023 09:34:00
#3 Опубликовано: 18.05.2023 10:07:22
Javier Ochoa
Javier Ochoa
Hi Jean,
Thank you for the worksheets, they will help me to think more like the way Smath Studio was thought to be (CAS).
#4 Опубликовано: 18.05.2023 11:31:13
Hi Jean,
Thank you for the worksheets.
They will help me to think more like the way Smath Studio was thought to be (CAS).
Augmented/refreshed ... Cheers ... Jean.
Inst_Colebrook MOODY.sm (31,64 КиБ) скачан 1668 раз(а).
