Functions descriptions in html files
Functions descriptions in html files - Descriptions in html files - Сообщения
#1 Опубликовано: 13.12.2012 20:09:50
Diego Jarrín
Diego Jarrín
7 сообщений из 14 понравились пользователям.
The descriptions of functions are not visible in html files when you put them over the functions or in the left side of the functions, but if you put them in the right side of the functions, the descriptions are visible.
If you print a pdf or an image of the file with functions and descriptions, all the descriptions are visible; I think that only the html output cuts the descriptions because it converts the functions (and the stuff in math mode) into png images, but it does this with an specific graphic area of the functions (with or without descriptions), the descriptions are not included in this graphic area, so they are not visible.
comments descriptions html.zip (3,49 КиБ) скачан 450 раз(а).
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
Radovan Omorjan 14.12.2012 07:39:00
#2 Опубликовано: 14.12.2012 08:46:11
I can confirm that as well.
