Beta: SMath Studio 0.99.7251 (08 November 2019)
Beta: SMath Studio 0.99.7251 (08 November 2019) - Сообщения
#1 Опубликовано: 08.11.2019 12:19:40
Группа: Super Administrator
Изменения, входящие в версию 0.99.7251
Разное
  • Calculation error introduced in previous beta version fixed in symbolic engine;
  • Calculation performance improved;
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_7251.Mono.tar.gz (1,4 МиБ) скачан 5132 раз(а).
SMathStudioDesktop.0_99_7251.Setup.msi (2,28 МиБ) скачан 20980 раз(а).
sergio 08.11.2019 13:19:00, NDTM Amarasekera 09.11.2019 03:44:00, Serg 13.11.2019 03:12:00
#2 Опубликовано: 15.11.2019 11:58:51
Ruben Sidranski
Ruben Sidranski
Blackout issue
I have the same issue (0.99.7251.32800) with the acoustic file on https://en.smath.com/forum/yaf_postsm59725_Summation-of-log-functions.aspx#post59725
#3 Опубликовано: 15.11.2019 12:12:56
As soon as it was noticed, I gave the cure.
Why not suite the original thread ?
#4 Опубликовано: 21.11.2019 13:19:08
Ruben Sidranski
Ruben Sidranski
Why not suite the original thread?
Because it's still a bug that popped up on some of my other sheets. I also posted in the other thread
#5 Опубликовано: 21.11.2019 14:00:02
Because it's still a bug that popped up on some of my other sheets.I also posted in the other thread
As long as you can doctor in two clicks.
#6 Опубликовано: 21.11.2019 18:10:59
Ruben Sidranski
Ruben Sidranski
Andrey,
Bug alert. I was updating a snippet in this version and it lost ALL of the information. I don't know if the rest of the data is still in this file
RS_User Defined Units.smz (4,8 КиБ) скачан 1608 раз(а).
This snippet had an issue in 99.7030 too (Portable)!
Could it be the SMZ file format? I saved a version as SM and that appears to be OK. However, another file, not used as a snippet, saved OK in both formats. The regions or areas?
Alvaro 22.11.2019 00:42:00
#7 Опубликовано: 21.11.2019 20:45:19
Bug alert.I was updating a snippet in this version and it lost ALL of the information.I don't know if the rest of the data is still in this file
Use your backup, re-save
#8 Опубликовано: 22.11.2019 00:44:07
Andrey,
Bug alert. ...
Hi. I save as smz a file with an area, and have the same issue. appVersion = "0.99.7251.32800"
#9 Опубликовано: 15.12.2019 07:20:14
601 сообщений из 1 382 понравились пользователям.
The last two versions (7250-7251) are not working on fully updated Arch Linux with Mono.
7219 is working but it has two glitches which are lowercase greek character related.
#10 Опубликовано: 02.01.2020 15:40:05
The interactive "Getting started" guide has been updated to SMath version 7251. Most of the update work was spent on utilizing the new features of the text region
- Arial as default font (saves approx. 20-30% of space compared to Courier New)
- Usage of embedded math in text regions
The new version is marked as "beta". You need to install the latest beta version 7251 and some plug-ins.
sergio 02.01.2020 16:04:00, NDTM Amarasekera 02.01.2020 23:30:00, frapuano 03.01.2020 09:30:00, Alvaro 03.01.2020 13:49:00
#11 Опубликовано: 03.01.2020 12:02:08
Ruben Sidranski
Ruben Sidranski
Martin,
The NEW interactive guide is not showing up for me. On my end, it shows you posted this message 20 hrs ago. Did the updated file upload correctly?
Thank you for updating the documentation
#12 Опубликовано: 03.01.2020 16:20:52
Martin,
The new version has been downloaded several times, thus it should be accessible.
Make sure to
- search for it in Extension manager as Example (not as interactive book)
- allow for beta versions in the online gallery
If that doesn't work, you still can download the file from the extension summary page as linked in my previous post. Then open it in SMath Studio just as any other sm file.
#13 Опубликовано: 13.01.2020 18:13:17
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
Has anyone noticed that the "newer" versions does not underline the space between words?
Is this intended?
Is there a way for me to change this?
Thanks!
#14 Опубликовано: 14.01.2020 07:52:20
Isn't true that you can underline something existing: word, letter, symbol
Did you mean underscore between two words ?
Do you refer to text, formula ?
#15 Опубликовано: 15.01.2020 04:24:16
genf
genf
6 сообщений из 72 понравились пользователям.
Доброго времени суток!
При наборе текста по умолчанию если нет пробелов, то этот текст является переменной, но как только появляется хотя бы 1 пробел эта переменная преобразуется в текст.
Если к этому тексту применять форматирование (например подчеркивание), то в версии 7030 пробелов не было, а в 7251 есть пробелы (разрывы) в подчеркивании:
Probely v podcherkivanii.sm (1,45 КиБ) скачан 1611 раз(а).
Спасибо!
Еще всплыл один вопрос: сейчас по умолчанию шрифт изменился на Arial.
Можно ли это умолчание поменять? Дело в том, что при редактировании старых расчетов, а именно - добавление новых областей, шрифт в них не меняется.
В итоге получается так:
Ryan Freund 15.01.2020 12:28:00
#16 Опубликовано: 15.01.2020 12:24:41
Ryan Freund
Ryan Freund
Sorry for my delayed response. What genf shows is what I'm talking about.
I want all text and spaces between underlined like this
Not just the text like this
I beleive the first instance is fairly standard for most text editor applications.
Also if I change the text to Courier New it works as I expect. If it is Arial (or others) it does not.
Thanks again
#17 Опубликовано: 15.01.2020 13:16:26
Writer region does it piece wise or global.
Davide Carpi 16.01.2020 08:35:00, Serg 17.01.2020 03:38:00
#18 Опубликовано: 15.01.2020 16:14:07
Ryan Freund
Ryan Freund
@Jean - Good point. I suppose that is a 'workaround' for now.
#19 Опубликовано: 17.01.2020 03:38:07
genf
genf
Ну это как вариант, но в 7030 то все нормально было ведь.
Как оказалось это проблема в шрифте Arial, с другими такого нет (например Arial Narrow).
Как быть со шрифтом в заголовке области?
#20 Опубликовано: 01.04.2020 07:58:28
Mathys
Mathys
Hello dear Smath fans,
with v0.99.7251 I cannot open any longer the "Format..."
menu with the right mouse button on inserted x-y-Plots.
After clicking on it, Smath is freezed.
After minimizing Smath to the task bar with third party tools
and reopen this Smath process again from the task bar
I am able to edit the open document without issues.
But as soon as I try to use "Format..." again on any x-y-plot,
the freezing happens againg. So the usual format pop-up
window does not appear at all.
Is this the right forum group for this issue?
Or is it better to place it elsewhere? E. g.
"SMath Studio Forum » SMath Studio » Bugs & Problems"
Thanks and regards
P.S.:
After some testing with parallel installation of
  • stable version v0.99.7030 and
  • beta version v0.997251
and after deleting all plugins and reinstallation
of a couple of required plugins the problem of
missing "Format..." popup for x-y-plots disappeared.
Strange. ---> I will monitor and report any new findings.
