SMath units
SMath units - Wrong units - Сообщения
#1 Опубликовано: 24.11.2023 05:13:51
Oichi
Oichi
4 сообщений из 35 понравились пользователям.
For a simple harmonic oscillator with mass "m" (kg) and spring constant "k" (N/m), the angular frequency of oscillation is sqrt(k/m).
If we used the SI units, the angular frequency unit should be (rad/s) but when I use units in SMath it gives the answer in Hz..
So, is there a way that I can correct the units for an answer? Thanks in advance
#2 Опубликовано: 24.11.2023 17:38:44
Oscar Campo
Oscar Campo
You can change units in this way...
Oscar
Oichi 25.11.2023 00:36:00
#3 Опубликовано: 25.11.2023 00:13:01
... Unit User Hz ... rad_s.sm (2,82 КиБ) скачан 1406 раз(а).
Oichi 25.11.2023 00:40:00
#4 Опубликовано: 25.11.2023 00:40:02
Oichi
Oichi
Thank you all ^^
Oscar Campo 25.11.2023 03:57:00
