Problem with while function
Problem with while function - Сообщения
#1 Опубликовано: 16.02.2009 23:24:49
dominator86
dominator86
I'm not sure but I think it's a bug. I tried to use the while function and when I want to converge a number to a constant there is no problem. But when I want to converge two numbers to each other like below, the program stops working.
Example:
x:=0
a:=20-2*x
b:=15-x
while a>b x:=x+1
#2 Опубликовано: 16.02.2009 23:54:23
2 343 сообщений из 4 043 понравились пользователям.
Группа: Super Administrator
This is not a bug.
Second line (a:=20-2*x) program calculate as a:=20, becouse you've define x:=0; third line has similar result, so your condition in while loop is allways true.
Here is solution:
(download an example)
