Plot Zoom not functioning properly
Plot Zoom not functioning properly - Moving the scroll wheel only zooms out no matter what direction it rolls - Сообщения
#1 Опубликовано: 16.12.2012 12:26:59
dCassidy
dCassidy
Hi
When I move my scroll wheel on the mouse, the zoom only zooms out no matter what direction the wheel is moved in. I have to delete the plot and start over. What am I doing wrong? I'd really like to be able to manually input limits for the axis's using the key pad.
Great Program!
#2 Опубликовано: 16.12.2012 21:15:42
Diego Jarrín
Diego Jarrín
7 сообщений из 14 понравились пользователям.
Use the plot options that are displayed on the right side panel. If the scale option is selected, it will zoom out your plots, if you select the refresh option, your plot will be redrawn, I know you can define the plot intervals of what you want to plot using an if statement:
Example.
For more information read the Wiki/graphs.
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
