A function for finding constrained minimum
A function for finding constrained minimum - mb10@live.it - Сообщения
#1 Опубликовано: 12.09.2013 15:53:02
mb10
mb10
9 сообщений из 20 понравились пользователям.
Attached is a snippet function for calculating the constrained minimum of a scalar function J(x) of several variables.
More specifically it solves the problem:
minimize J(x) in the domain xm <= x <= xM
subject to:
g(x)>=0; (a vector function of m potentially nonlinear inequality constraints)
A*x = b; (r linear equality constraints, A being an rxn matrix)
The algorithm has been adapted from this article (in particular from eqn. (7) on page 4):
http://www.ajbasweb.com/ajbas/2011/894-909.pdf.
minimizerExamples_v01.sm (39,4 КиБ) скачан 1679 раз(а).
Radovan Omorjan 12.09.2013 16:12:00, Martin Kraska 12.09.2013 16:15:00
#2 Опубликовано: 12.09.2013 16:14:21
I attached a version with function arguments. In the definition, the formal parameter is a function name with the numbers of arguments given, in the call the actual parameter is the function with an UNDEFINED variable as dummy argument, Thus, minimize(J(x), g(x), x ... won't work because x is bound to the initial values vector.
minimizerExamples_Kr.sm (38,12 КиБ) скачан 1711 раз(а).
Radovan Omorjan 12.09.2013 16:16:00
#3 Опубликовано: 12.09.2013 17:07:22
mb10
mb10
@ Martin Kraska:
With your changes (and changing the names in the body of the algorithm as well), it seems to work fine now, and I will soon update both files accordingly.
Thank you very much for your explanations!
mb
#4 Опубликовано: 12.09.2013 18:26:21
mb10
mb10
The attachments in the first post have been updated according to the suggestions of M. Kraska.
