symbolic calculation
symbolic calculation - Сообщения
#1 Опубликовано: 31.07.2020 17:46:34
misaelsk2
misaelsk2
how to clear a variable in an equation, for example P.V = R.T.n, how to make the variable "T" appear, is there a command that does that?,
#2 Опубликовано: 01.08.2020 07:57:58
#3 Опубликовано: 01.08.2020 08:20:09
I hope I understand the problem
magnus_01.sm (4,89 КиБ) скачан 1741 раз(а).
you need to install the Maxima plugin (and have Maxima installed)
#4 Опубликовано: 02.08.2020 00:29:42
misaelsk2
misaelsk2
I opened the file, but I get this "Initializing error. Please check path to Maxima under Insert> Maxima> Settings.",
I have wxMaxima installed and also the Maxima plugin on Smath
