1 страниц (3 вхождений)
Problem with opening the file - I open the file and 5 sec later close and disappear itself - Сообщения
Podwojny balkon.sm (2,79 МиБ) скачан 1610 раз(а).
WrotePodwojny balkon.sm (2,79 МиБ) скачан 1610 раз(а).
Here is your manually recovered file.
Apparently there was an empty text region.
It was starting at line 8662.
That was causing the error.
Removing it made the file tick.
Podwojny balkon1.sm (2,79 МиБ) скачан 1657 раз(а).
<region left="342" top="56124" width="63" height="27" color="#000000" fontSize="12">
<text lang="pol" width="55" fontFamily="Times New Roman" fontSize="12">
<content>
<p> \[REGION[c655dfafd07249abba46f86987917195]]\[m2]</p>
</content>
<regions>
<region id="c655dfafd07249abba46f86987917195" left="10" top="0" width="17" height="26" color="#000000" fontSize="12" />
</regions>
</text>
</region>
WroteWrotePodwojny balkon.sm (2,79 МиБ) скачан 1610 раз(а).
Podwojny balkon1.sm (2,79 МиБ) скачан 1657 раз(а).<region left="342" top="56124" width="63" height="27" color="#000000" fontSize="12"> <text lang="pol" width="55" fontFamily="Times New Roman" fontSize="12"> <content> <p> \[REGION[c655dfafd07249abba46f86987917195]]\[m2]</p> </content> <regions> <region id="c655dfafd07249abba46f86987917195" left="10" top="0" width="17" height="26" color="#000000" fontSize="12" /> </regions> </text> </region>
good morning I'm having the same problem how do I open this msdos tab to fix?
