subscript in text region - subscript - Сообщения
I'm not sure if the built-in text region handles subscripts.
WroteIf you use writer region plugin, you can use Ctrl+Shift+B. You can install writer region by going to tool->Plugins->Clicking on Local Storage and choosing Online Gallery -> Scroll to Writer Region and double click to install.
I added it, but if I hit Ctrl+Shift+B, in the text region, nothing happens.
Then you can type as usual.
Note: If you right click on the writer region and choose settings, you get a microsoft word-like toolbar.
WroteNote: If you right click on the writer region and choose settings, you get a microsoft word-like toolbar.
... from there, drag the ribbon down the work sheet,
select the letter(s), number(s) you want to subscript,
click on the icon that shows subscript ... try.
Generally you will to increase the font size of the subscripted.
WroteWroteNote: If you right click on the writer region and choose settings, you get a microsoft word-like toolbar.
WroteTo add a writer region to your sheet use crtl+shift+w.
Thanks. The person next to me, got a message that the text writer region could not be added and to remove it, but it worked for me.
Are yall running the same version of SMath? Did it fail when they tried to install writer region or when they tried to add a writer region using ctrl+shift+w?
He picked the wrong addin. It is working now.
