mcdconv_tool_v5.zip (67,06 КиБ) скачан 36 раз(а).OK. Here is my first try. It appears to work correctly for the two or three old worksheets for which I had pdf print-outs as well as the original .mcd files. I also fed it the worksheets for Krieth Principles of Heat Transfer. At the time, I was using WaterSteamPro for properties of water, air and products of combustion for my own designs; hence some references to wsp.
If you get Claude to make significant additions to the method, e.g. confirming additional details in the binary file code, please share here.
Отредактировано 30.10.2026 13:32:48
