File Open/Save/Save As errors with WinMo 6.5
File Open/Save/Save As errors with WinMo 6.5 - Сообщения
#1 Опубликовано: 04.08.2009 03:21:13
kfchen
kfchen
First of all this is an amazing program for the WinMo handheld that I have. Just curious if there's a work around for File Open/Save/Save As "FileNotFoundException Could not find file '.\' error"?
#2 Опубликовано: 04.08.2009 08:46:44
Группа: Super Administrator
I can't reproduce your finding. Please, provide your device name and SMath Studio version. Is this exception appears when you try to open Open/Save File Dialogs first time or after some other actions?
Best regards, Andrey Ivashov.
#3 Опубликовано: 05.08.2009 03:17:44
kfchen
kfchen
I have a HTC Touch Pro with Windows Mobile 6.5 |HERM|ROM|6.5|WWE| ** EnergyROM 'Aurora' (23016) ** || Built August 1st || SMath Studio 0.82 (build:3477), every time when I try to use File Open/Save/Save As, tried hard reset, multiple reinstalls. Other functions of SMath works fine (calculations, plots, etc). Any ideas or is it just this particular custom ROM / a general issue with Windows Mobile 6.5? I will try other 6.5 ROM releases as well to see if there is same issue.
#4 Опубликовано: 05.08.2009 15:47:12
I've tried Windows Mobile 6.5 and it's OK.
#5 Опубликовано: 06.08.2009 03:23:56
kfchen
kfchen
Thanks Andrey, I have confirmed that it works with other WinMo6.5 ROMs and also after reinstalling an updated version of the ROM this issue seems to have resolved itself. Most likely a bug with previous version of ROM not SMath.
