Smath and Google Docs Spreadsheets
Smath and Google Docs Spreadsheets - Сообщения
#1 Опубликовано: 17.10.2011 11:19:58
kilele
kilele
Now that you can set up Google Docs for Offline working, it'd be interesting to make Smath interact with their spreadsheet.
Another suggestion for plugin developers: you might consider making use of wxMaxima at
http://andrejv.github.com/wxmaxima/index.html
Edit: nevermind, it seems that offline editing is available only using their browser.
#2 Опубликовано: 05.01.2012 18:09:54
amit28it
amit28it
0 сообщений из 16 понравились пользователям.
What google spreadsheet can be used offline .?So how is this possible but google spreadsheet is the way through which we can share and work but through offline how is this possible .Please explain it brief .Thanks ..
#3 Опубликовано: 06.01.2012 02:12:31
kilele
kilele
Gspreadsheets supports offline viewing from Chrome browser.
Look at
http://gmailblog.blogspot.com/2011/08/using-gmail-calendar-and-docs-without.html
I wonder if it'd be possible an interaction between smath and MS Office Web Apps
#4 Опубликовано: 14.02.2012 06:10:53
amit28it
amit28it
Hi ,
It was nice to hear this about google spreadsheet from you .I was unaware of this good stuff that you provided .Thanks for this . i visited this blog and find it quite informative .
SMath: don't use links to tutorvista from now. Otherwise your comments will be classified as spam.
