1 страниц (4 вхождений)
Simpson versus Trapezoidal method used for integration - The Trapezoidal method is compared with the Simpson method, both using Richardson extrapolation - Сообщения
I was trying to understand how to use the numerical integration with the Simpson and Trapezoidal method. I could also explain the difference between the two methods, based on an example found in the forum.
I also applied the numerical integration to found the flow rate of a pump during the start up and shut down processes, which is useful to some degree for many engineers.
Hope it help,
Kind regards,
romberg_integration_exmple.sm (37,43 КиБ) скачан 1707 раз(а).
romberg_integration.sm (30,11 КиБ) скачан 1755 раз(а).
Hope it help,
Kind regards,
Trapeze suits better certain functions vs Simpson.
The converse is true: Simpson fits better certain function vs Trapeze.
Romberg/Simpson kernel is a much different story.
It converts the range of the variate of integration [0 ..1]
Last example: Trapeze better than Simpson ... poor vs ∫kernel.
Cheers ... Jean.
Integral COMPANION Trapeze.sm (36,12 КиБ) скачан 1762 раз(а).
Cheers ... Jean.
Javier Ochoa 16.05.2023 19:20:00
Hi Jean,
I will take a look at your worksheet in orden to understand your advice.
I always wish to learn a bit more.
Thanks,
Thanks,
WroteHi Jean,
I will take a look at your worksheet in order to understand your advice.
Visit Samples about Trapeze Integration, will be attached today.
Cheers ... Jean.
