Overwrite file question
Overwrite file question - exportData.CSV - Сообщения
#1 Опубликовано: 07.03.2019 00:06:25
RegCurry
RegCurry
0 сообщений из 57 понравились пользователям.
Is it true that exportData.CSV[matrix,"filename"] will not overwrite the csv file "filename" and the original file "fiename" must be deleted or moved from the folder to which you are trying to write the csv file?
Thanks,
Reg
#2 Опубликовано: 07.03.2019 00:38:06
RegCurry
RegCurry
Seems to be working now with no changes to code. There are gremlins in my computer.
