Algebraic manipulation
Algebraic manipulation - Simplify - Сообщения
#1 Опубликовано: 13.12.2017 11:24:03
elmo788
elmo788
If this has been asked before, I apologize but I was able to find an answer. Does Smath not support algebraic manipulation?
I tried to find substitute, expand, factor, simplify and do not see that supported. It was one of the main reasons I used MathCad.
I was hoping this software would be similar. Am I just completely missing where this functionality is located or does it not support this?
#2 Опубликовано: 13.12.2017 13:47:32
1. "substitute" Consult Martin latest handbook ... work yourself an example.
2. "simplify" from Smath menu. Will simplify some simple expressions like
pencil/paper. More maths expressions will expand in the executable form
completely useless. Example: a continued fraction of 12 terms will expands
serially over "zillion pages".
3. "expand, factor" ... transit via Maple ... maple(,,,,code the expression)
Smath is not a Mathcad clone.
#3 Опубликовано: 13.12.2017 13:49:52
... I collected a maths expression in 6 different equivalent forms.
Mathematica couldn't even find so many !
#4 Опубликовано: 13.12.2017 19:08:46
This is a page from the interactive handbook. You can install it via extension manager (Tools> Plugins)
Many features of Maxima are accessible via Maxima plugin.
Examples maxima handbook.sm (44,43 КиБ) скачан 1457 раз(а).
frapuano 15.12.2017 08:55:00
#5 Опубликовано: 27.01.2026 09:24:19
Fabbro
Fabbro
0 сообщений из 25 понравились пользователям.
.....in addition to the above algebraic-manipulations commands, is there any command allowing comparison btw two long, complicated
symbolic expression?
Thanks
#6 Опубликовано: 27.01.2026 20:00:51
Hi. This proves nothing, but it shows that numerically they are indistinguishable, at least in the domain considered..
show-num-equality.sm (4,97 КиБ) скачан 696 раз(а).
Отредактировано 27.01.2026 20:03:15
