How to replace text?
How to replace text? - Сообщения
#1 Опубликовано: 30.03.2025 11:37:42
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
There is only find functionin Edit menu, but there is no replace function.
How to use replace for math input and text input?
#2 Опубликовано: 30.03.2025 23:29:16
Find everything you need in the text Region Utilities plugin, by Davide Carpi
#3 Опубликовано: 11.04.2025 14:05:58
⚜ Kenny Lemens, P.E. ᵂᴵ
85 сообщений из 179 понравились пользователям.
Greetings,
If you have a large programming statement, you can use 「F8」 to update all the variables within a math statement.
Unfortanelty, the search/replace function you are asking about is not part of default interface.
May this be of Good Help;
