Operation cannot be performed with units and solution exceeding max allowed numerical values
Operation cannot be performed with units and solution exceeding max allowed numerical values - Сообщения
#1 Опубликовано: 17.11.2015 14:47:22
aero
aero
0 сообщений из 12 понравились пользователям.
I am getting the error of "Operation cannot be performed with units but I redefined the values with new variable names which has no unit but I am still getting the same error. I need suggestions to resolve this issue. I have attached the Smath file and a screen shot of the same.
Thanks !
#2 Опубликовано: 17.11.2015 17:01:25
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
Post the file.
#3 Опубликовано: 17.11.2015 17:07:51
dio pants
dio pants
16 сообщений из 180 понравились пользователям.
What is this a calc of? Do you have a good known example to check against?
Check your operations- calcs dependent on variables need to be below or to the right.
Your units are goofy. break out a pencil and paper and do the dimensional analysis to see how your calc is working, or really not working. SMath is REALLY good at keeping track of units. it is doing exactly what you are telling it to do.
#4 Опубликовано: 17.11.2015 20:23:20
Seems that tanh(x) returns a "number above the max" error if x > 354, a "division by 0" error if x < -228 (reported as BUG SS-2284)
About the units, the tanh argument must be dimensionless; m*Lc can't be dimensionless because m is not the inverse of a length (your definition of m contains the Boltzmann constant and 2 lengths)
#5 Опубликовано: 18.11.2015 04:40:35
2 342 сообщений из 4 041 понравились пользователям.
Группа: Super Administrator
Hello.
I've fixed this issue and here is corrected SMath.Math.Numeric.dll SMath.Math.Numeric.dll.7z (25,23 КиБ) скачан 679 раз(а).
Please put it into installation directory of SMath Studio.
Fix will be included into new version of the program.
Regards.
Davide Carpi 18.11.2015 05:18:00, sergio 18.11.2015 05:48:00, Radovan Omorjan 18.11.2015 06:22:00, ioan92 18.11.2015 09:16:00
