derivate problem composite function
derivate problem composite function - Сообщения
#1 Опубликовано: 03.06.2015 11:20:44
dav47
dav47
Hi to all, I create a composed function, but I don't understand what is wrong.
Please help
#2 Опубликовано: 03.06.2015 12:08:04
dav47
dav47
I attach the file to clarify the problem
2spline.sm (26,73 КиБ) скачан 1181 раз(а).
#3 Опубликовано: 03.06.2015 12:54:03
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
When defining a1, b1, c1.. etc, you define them as rows of a matrix (notice how they are still in parenthesis), and they remain a single entry matrix. This causes an error later on since you can't take a derivative of a matrix.
Instead of extracting the row, extract the element by using the "el" function, or write the matrix name followed by "[" and the row number.
eg. a.1 : M[1
Davide Carpi 03.06.2015 19:47:00
#4 Опубликовано: 03.06.2015 16:35:28
The cases() function helps a lot in writing piecewise continuous functions in a readable way.
2spline_Kr.sm (23,73 КиБ) скачан 1223 раз(а).
#5 Опубликовано: 04.06.2015 03:45:01
dav47
dav47
Hi, Ernesto and Martin.
Thank you for your help.
I'm new to the use of smath studio. I understand my mistake....It's a mathematical error!
Now I have istalled the Function extension.
Bye
Davide
